You must configure Transparent Port UNI. For more information, see Configuring Transparent UNI.
You must associate a T-UNI LACP MLT with a VLAN before mapping the LACP MLT to a T-UNI I-SID.
Caution
Ensure that a T-UNI LACP MLT is always associated with a VLAN (even if it is the default VLAN) before adding it to a T-UNI I-SID. Otherwise, traffic is not forwarded on the T-UNI LACP MLT.
Use the following procedure to associate a port and MLT with an I-SID.
- Select ISID.
- On the Service tab, select a row with the type configured as elanTransparent.
- Select ELAN.
- Select port members.
- Select MLT IDs.
- Select Apply.
Service Field Descriptions
Use the data in the following table to use the Service tab.
Name |
Description |
PortMembers |
The set of ports that are members of the ELAN Transparent service type. From the available ports, you can select a single or multiple ports. |
MltIds |
The set of bits that represent the MLT IDs. From the available MLTs, you can select any, or all of the MLTs to be a part of ELAN Transparent I-SID. |
